TV won't turn on - "V" icon on front 2 x quick flashes every 3 seconds
TV model is Sharp Aquos LC-46LE820X LCD (purchased in 2011)
When trying to turn it on, there is no sign of life other than the front panel "V" icon flashes with 2 quick flashes, which repeats every 3 seconds.
I understand the type of icon flashing indicates different fault codes. Does anyone know with this flashing indicates?
Is dit een goede vraag?
1 Opmerking
Oldturkey03, I went through your list of checks and can advise as follows;
# Unplugged TV then plugged it back in & turned on after 5+ minutes. The double quick flash was the only life visible on the TV.
# I pressed the menu button and the flash sequence changed to 2 quick flashes, then after 3 sec 1 quick flash. This sequence repeated ongoing.
# I then pressed Vol-, Input & Power buttons on remote, but the sequence didn't change. Tried the same button on the TV without any change either.
# During the above, the screen remained off.
I just received an email from Sharp's Support department stating "2 flashing lights indicate a Power Failure in The PWB Board". Not sure if your assessment would also indicate this?
I tried uploading a short video of the double quick flash (not sure it it came through).
[video|5907]
door Geoff S
