Ga door naar hoofdinhoud
C:\windows\system32\command.com parameter is incorrect, how do I fix t
My computer acts like its going to load correctly and then an error message pops up and doesn't load anything. Any tips on how to fix?
Is dit een goede vraag?
1 Opmerking
Did you recently use Spybot i.e. to clean your computer? What OS are you using?
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
You can try to boot into Safemode and do a system restore to a point prior to when this error occurred.
Was dit antwoord nuttig?
Het nuttigste antwoord
try repairing your windows by using your installation disk select repair and when the command prompt appears type the following after the command prompt:
chkdsk /r /p
Score 1
Since you are not getting to windows, you will not be able to install new programs.
Most likely your windows is corrupted.
You may try to repair the windows by using the windows OS CD.
If that does not help you may have to reinstall windows on your system again.
You can do this by the windows CD which you got with the purchase of your system.
Instead of install choose to repair windows and follow on screen instruction to finish installation.
Good Luck.
Voeg je antwoord toe
Kpace zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 2,107
