Ga door naar hoofdinhoud
Screw driver type info
What is the type of screw driver used to open the back case ?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @utsabsingh
For the back cover you will need a Torx screwdriver, not sure if it is a T5 or a T30 as I don't know the laptop, but in any case you may need both, depending on what else you want to do in the laptop.
Here's the hardware maintenance manual for the laptop series.
On p.33 you'll find a list of the tools required.
On p.51 it shows how to remove the back cover for your model series.
Note: 3 of the 9 screws in the back cover are a different length to the other 6 so make sure you either keep them separate or remember where they go when reinserting them.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Utsab Singh zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 353
