Help - Has anyone already done this?
My Roomba 692 lights up the CLEAM key in green but it doesn't move, nor does an error message appear, either manually or via the APP. It turns on and does nothing. can anybody help me???
Is dit een goede vraag?
@sandronardi sounds like some issues with the firm/software. Try this. Get a Phillips screwdriver and start off by removing the screw for the side brush. Once the screw is removed, pull the side brush off. Next remove the bottom cover by removing the Philips screws. Now, remove the battery and keep it out for a short while (30-60 sec) should be enough. Then replace the battery and reassemble your Roomba and give it a try. Let us know if it helped.
Now, since iFixit does not have a guide for this and if this works for your Roomba, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Was dit antwoord nuttig?
You can try to hold the clean button for around 30 seconds, or when you hear a beep. I believe it does a hard reset, and it should solve the issue. If not, you may try @oldturkey03's steps.
Friend, the CLEAN button is on, it makes contact because I hear the plate click, but it doesn't do anything else. I also tried to restart via the APP but nothing happened.
I know it is on, but even if it is on, still hold the clean button for 30 seconds.
I'll try and tell you
Friend, it didn't work
Okay. You can now try @oldturkey03's steps
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 49
Altijd: 546
Does the Roomba make any sound at all?
door EverythingAwesomeTech
No, it does not make any sound, only the CLEAN button is lit
door Sandro Nardi
Friends;
I disassembled the entire Roomba, removed the Motherboard, washed it with detergent and dried it with an air compressor. I reassembled everything and...It worked. I think it must be dirt or bad contact with a component.
door Sandro Nardi
