Ga door naar hoofdinhoud
The Dyson DC62 is an upright cordless vacuum cleaner that is designed to pick up dust and allergens like pet dander.
Why is my new battery overheating. Replaced the previous battery
Replaced previous battery not holding the charge long enough. All filters cleaned or replaced motor unit blew out. Reassembled. Using it this morning and battery got very hot and run out of charge.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Batteries get warm/hot when passing a lot of current either charging or discharging because of the internal battery resistance.
If you are using it and it gets very hot, either the battery is bad or the device is drawing too much current. For a vacuum, it could be a bad motor, a very tight brush roller, or plugged airways.
Was dit antwoord nuttig?
Voeg je antwoord toe
Mervyn Tannahill zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 16
Altijd: 238
