Ga door naar hoofdinhoud
The Wii Nunchuk was an accessory created by Nintendo for the Wii system in 2006.
Loose Nunchuk stick, how and what to replace it with?
My Nunchuk's stick is loose and started drifting. At rest, it has way more give than my non-drifting Nunchuk's, which indicates to me that the internal stick has worn down. Is it possible to replace the internal stick without replacing the entire stickbox, and if so, where would I get a replacement?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi!
Did you already opened it? Is it the plastic thats is loose? Or the actual analog stick it self? Replacing the analog stick requires soldering but this will fix the drift.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Cych zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 20
Altijd: 353
