Won't turn on or charge no indicators and no lights
I replaced the charging port and still nothing and the charger is good I think
Is dit een goede vraag?
@babyfoxy35 you really have to check your charger. Now would be a good time to invest in an ammeter to see how many, if any amps, your computer will draw from the charger. Since you already changed the DC in jack, the fault can easily be with the Mosfets on the board. If you want to go that route, we will need to see your board. We will also need to know what motherboard your computer has. The number for that should be printed on the side that faces the keyboard.
You will need the basic tools like a good multimeter as well as a soldering station etc. if you want to try and fixit. Post some good pictures of your board with your question. That way we can see what you see
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 35
@babyfoxy35 If you add pictures of the charge port you have replaced and other parts that you suspect would have a fault we can give better advice and see the same as you do when looking at the charging port.
Voeg afbeeldingen toe aan een bestaande vraag
door Markus Norstrøm
