Ga door naar hoofdinhoud
Een USB-kabel (Universal Serial Bus) is een veelgebruikt type kabel dat wordt gebruikt om apparaten zoals computers, smartphones, printers, camera's en andere elektronica aan te sluiten. Het is ontworpen om gegevens en stroom tussen apparaten over te dragen, en wordt ook vaak gebruikt voor het opladen van apparaten.
Broke one side of my 16 foot ubs type c
hey guys i have a c to c cable and one end broke i cut the end that was broken and there is at lest 9 single wires and then 4 that are shielded twisted pair. I need guidance on this my self and were to get the type c connector for that, its a 16 foot cable so id rather not chuck it out
Update (04/16/24)
ok I did forget to mention it was meant for the quest 2 and it was the 90 degree bend end.
The info given is great by the way
Is dit een goede vraag?
Score 1
1 Opmerking
the part if anybody ever needs it on digikey is
https://www.digikey.ca/en/products/detai...
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@anora5807 the USB-C luckily has a standard but the wire color does not. Download the pinout book from here Page 49 will tell you what signal is on what connection. Now you will need to get something like this testboard (either male or female end, since we do not know which end of yours is damaged). You can now determine which wire (color) goes to what connection on your replacement connector. Again, not sure if it is a male or female end, check Mouser.com or Digikey.com (as well as many others) for replacements.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
@anora5807 then this will only work if you know what the pinout is on the Quest 2 side. Ultimately, I would think that it keeps the same standard. Check mouser.com or digikey.com as well as many others for the USB-Connector you will need.
door
Voeg je antwoord toe
Anora zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 22
Altijd: 423
