Unit turns off after a few seconds.
My friend's xbox turns itself off after being powered on for less than a minute. Could this be a fault with the power button?
Is dit een goede vraag?
Hi Mark!
This could be caused by multiple things.
1: It could be that the Xbox One X is overheated and so, it needs it's thermal paste (and thermal pads) replaced.
2: The power supply could be faulty causing this, and need to be replaced.
3: The front circuit board is faulty and need to be replaced.
First I would try option 1 (this is always a good thing to do, to replace those on time to time).
If that didn't worked, I would try option 2. If it's still causing the same issues then return the new power supply and get a refund.
And at last I would try option 3 to replace the front circuit board.
If all of those options didn't work and it's still turning off by it self, it's probably motherboard related... And so, then the motherboard need a replacement.
Good luck!
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 13
