Removing bottom drive cover ez walk mower
How do I remove bottom drive cover on ez walk mower. I have 1 bolt out which is all I can find. I don't want to reef on it and break it.
Is dit een goede vraag?
Score
0
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 20
Are you talking about the plastic drive belt cover on top of the mower deck with one bolt right about in the middle of it? Here's a link to an exploded view .
https://www.ereplacementparts.com/crafts...
door moe_r
yeah, i got the bolt out but didn't want to break any tabs off by pulling it too hard. do you just pop it off.
door BLAIR SCHIMMING
I believe that if you push on the front of this cover while gently lifting, a tab will release at the front of the cover and you should be able to lift it off. It appears there are two tabs at the rear of the cover that should slide out once the front tab is released.
door moe_r
