Ga door naar hoofdinhoud
Repair and disassembly information for Google's Pixel 8 smartphone, released in October 2023. Identified by model numbers G9BQD, GA04851-US, GKWS6, GPJ41, and GZPFO.
do I need to replace the adhesive?
If I open it up do I need to replace the adhesive?
Is dit een goede vraag?
Score 1
1 Opmerking
Short answer. Yes.
Longer answer. Depending on where you open it up you may damage the adhesive and it will be safer to replace it than not doing it. Replacing it will also ensure liquid resistance is kept.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I would recommend replacing the adhesive after you open the device up. The adhesive helps ensure dirt, dust, and water doesn't get into the device. Not replacing the adhesive could result in moisture damage, which would end up costing you far more than the relatively small investment.
Google Pixel 8 Screen Adhesive - Genuine
This custom cut adhesive film secures the display panel to the frame of a Google Pixel 8 smartphone. Afbeelding
Product
$3.99
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Grayden Hormes zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 196
