Ga door naar hoofdinhoud
De eerste 2-in-1 laptop van Samsung, met een 13,3" of 15,6" scherm, 8 GB of 16 GB RAM, en de keuze uit een i5- of i7 Intel-processor.
Issue with touch screen - fault or cable perhaps?
This is for the NP950QDB-KA1US. Galaxy Book Pro 360
The notebook screen stopped accepting touch response on the top 10mm of the screen, and a row of the round touch circles would display up there from time to time when moving the lid or trying to touch that region. They show up when restarting at times as well.
The notebook warranty ended in mid-2023. I ran through all of the Samsung updates, Windows updates, and with Samsung's text message support, backed up the files and did a Windows recovery reset, and tried recalibration of the touch screen several times, but the problem remains.
Now, the touch screen response seems to work on and off, but the top region still does not respond. It means you cannot maximize/minimize/close a full-screen window by touch. Also, when the row of touch circles appear, they activate any buttons that are beneath them.
I do not have the tools to pry the notebook open, and despite curiosity, do not have much time to dig around. The question is, how likely is this a loose or slipped cable issue vs. a hardware fault?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Have you tried reinstalling the driver for the touchscreen? Should be available in the device management program.
Press 'Windows + R' on your keyboard, type devmgmt. msc, and hit Enter.
If this doesn't help I would probably have a look at this manual
https://www.manualslib.com/manual/315328...
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
Everything was reinstalled with the Windows reinstall, done twice. The issue appears in response to movement and gentle tapping of the lid, so it is a hardware issue. My question is whether anyone else has seen this issue before, and whether anyone has seen a partially loose cable cause this issue?
door
It can either be that or a broken line in a cable depending on connection type
door
We decided to send it off for repair, so we will see what happens. Thank you!
door
@sean72 Always happy to help.
door
Voeg je antwoord toe
Sean72 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 30
Altijd: 518
