kenmore elite smartwash HE4t error message F and SUD
My washer shows both error messages and will not finish through the spin cycle. I took off the front and emptied the drain with no luck
Is dit een goede vraag?
elisha, the SUD error on these machines is usually displayed when the motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. This could be caused by a bad pump, an extra heavy load, excessive detergent, or excessive suds. "If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
• Check the drain hose and make sure it is not plugged or kinked
• Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
• Check/ Clean Drain Pump Filter of foreign objects
• Check Drain Pump
• Check the Pressure Switch
• Check CCU"
You can remove the lower access panel and try and check the drain pump while it is in a drain cycle. If the pump seems to be buzzing or vibrating but no water is being drained then likely the pump is bad. If you have a multimeter available, you can check for resistance of the pump motor.
Was dit antwoord nuttig?
If this is a front loading machine, there is a device panel under the drum.
Get a 2x4 or two, and tip the machine back slightly, slide the wood or othe prop under the front
Remove the device panel
Get a bucket.
You should see a clean out, carefully open the clean out making sure the bucket is under it. I don't recommend pulling it all the way out unless your drum is completely empty.
Remove all the debris from the cleanout
Replace the cleanout
Lower the machine
I ran my similar machine empty to make sure no leaks. And to clean remaining suds out
Replace panel
You should be good to go.
Thank you. I tried that and pulled out some debris. It still is not spinning. Any other ideas?
I am also having the same problem. The pump is functioning properly, there is no detergent build up, and the clean out has been cleaned out multiple times. Is there anything else I should be concidering before I simply give up and replace this machine?
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 97
Altijd: 22,286
