Ga door naar hoofdinhoud
Repair and additional information for the LG Refrigerator LFX25973**, a bottom freezer model with an ice-through-door feature and an anti-sweat heater switch, launched in 2011. This page covers information for model numbers matching the pattern LFX25973**.
2 Vragen Bekijk alle
LG lfx25973d Ice maker tray stops mid turn
Have a lfx25973d the ice maker starts to turn to drop the ice, stops midway gives off a annoying sounding clicking sound. I open it up I see it stuck mid rotation I then goes back to original starting point not dispensing the ice cubes.
Tried resetting it will work a few times dispensing ice then get stuck again. Any ideas before I consider replacing the whole ice making unit???
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @danb907
Here's the service manual for the model series that may help
Go to p.68 to see how to test the ice maker function.
If you decide to replace the ice maker, what is the full model number of the refrigerator as there appears to be different ice makers used in variants of the refrigerator model number that you posted?
Hopefully the following list may help to find the correct one for your model. Perhaps check if there's a part number on the ice maker itself to verify before ordering from a supplier. Search online for the part number only, relevant to your particular model, to find suppliers that suit you best.
According to this supplier here are the manufacturer's ice maker assembly part numbers, for the various model variants.
LFX25973D - Ice maker assembly part #AEQ73110203 Note: The Secondary (smaller) wire connector has 3 wires in it. If original ice maker has 6 wire connector see part number AEQ73110205.
LFX25973D (00) - Ice maker assembly part #AEQ72909603
LFX25973D (ASBCNA0) - Ice maker assembly part #AEQ72909604
LFX25973D (ASBCNA1) - Ice maker assembly part #AEQ72909604
According to one supplier here are the manufacturer's ice maker assembly part numbers, for the various model variants.
LFX25973D/00 - Ice maker assembly part #AEQ72909602 (replaces AEQ72909601) OR Ice maker assembly part #AEQ73110203 (replaces AEQ73110206, AEQ73110209)
LFX25973D/01 - Ice maker assembly part #AEQ72909604
Refrigerator Ice Maker Assembly - AEQ73110205 Afbeelding
Product
$154.99
AEQ72909603 - LG Refrigerator Ice Maker Afbeelding
Product
$216.99
AEQ73110203 - LG Refrigerator Ice Maker Afbeelding
Product
$198.99
AEQ72909602 - LG Refrigerator Ice Maker Afbeelding
Product
$153.99
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
DanB zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 26
Altijd: 46
