Weird thing happening with my converter box.
Hello,
I recently dug out my Apex converter box so I could watch TV from my Toshiba CRT television. I plugged it in, and pressed the power button, and it flashed red. Nothing showed up on screen. I held the button, and it continued flashing. That happened for a bit, until it turned green. The remote did the same. I saw a few white lines on-screen, and then nothing. I also heard some buzzing sounds when I pressed the button. I unplugged it and the high-pitched noise faded out along with the red light. The issue's very hard to describe in words. Is there any way to fix this, or is my converter broken?
Is dit een goede vraag?
2 opmerkingen
Hi @lappy48614311,
High pitched whine and noises could indicate problems with the power supply board in the converter
Disconnect the power to the converter box and open it up and check the condition of the capacitors on the power board to make sure that they're not leaky etc
Post some close up images of the board in your question Voeg afbeeldingen toe aan een bestaande vraag
door jayeff
@jayeff LOL, with the final answer being posted below, it appears you called it! Blown capacitor indeed.
door Jerry Wheeler
