Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Vragen Bekijk alle
On/Off switch not working
Hi All, This phone was water damaged I have given it some TLC and cleaned every thing with iso p Alcohol and works great.exept the on/off sleep button I have even taken that apart but no luck Any Ideas please Cheers
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
These things go bad after a few years. Try replacing the entire ribbon connector for the audiojack/power button. I've had to replace a few for customers throughout the years just because they drop the phone or it just wears out.
Was dit antwoord nuttig?
1 Opmerking:
Thank you That worked Brill
door
Voeg je antwoord toe
Kevin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 684
