Ga door naar hoofdinhoud
How do I reapply thermal paste on this laptop?
Hello, my laptop's CPU often heats up to 70-80 when gaming, this did not happen before. I want to reapply the thermal paste on the CPU with hope of it lowering these temps. When i search on google i get multiple different answers as to how i should apply the thermal paste, and which thermal paste i should use (Some even recommend thermal pads)
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @superres7
Here's the hardware maintenance manual for the laptop.
First go to p.60 to see how to disable the built in battery and then go to p.66 to view the procedure to remove/replace the thermal fan assembly so that you can refresh the thermal paste on the CPU.
If necessary you can also clean the fan once it is removed from the laptop as well.
Here's the ifixit Aanbrengen van koelpasta guide that may help.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
SuperRes7 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 80
