Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Laptop uitgebracht in 2019 door Acer. De Acer Nitro 5 bevat 8 GB RAM (uitbreidbaar tot 32 GB met de juiste hardware) en een rood verlicht toetsenbord.
How to replace screen?
My screen went all black after someone replaced and I don’t like how they did and I was wondering if I could do it myself
Is dit een goede vraag?
Score 1
1 Opmerking:
Never replace a screen without disconnecting both the battery and the charger first!
door Deel
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Hi Alloy,
Luckily replacing the screen on the Nitro 5 is not too complicated!
Here is a link to a YouTube video that will show you how to do perform the replacement yourself: Acer Nitro 5 Screen replacement - YouTube
and here is a link to a replacement screen (You can also find them on eBay): Screen for acer NITRO 5 AN515-54 SERIES. Replacement Laptop LCD Screen (laptopscreen.com)
If you're comfortable going a step further, I would disconnect the Main battery which can be done by undoing the screws holding the bottom plate. This Will just lower the chances of the screen getting damaged during installation.
I hope this helps, let me know if you have any other questions :)
Was dit antwoord nuttig?
Please folks, translate this (portuguese to english):
O problema mais dificil que enfrento é distinguir se o problema está na tela ou no flat cable.
O notebook caiu de uma altura de 20cm...no primeiro momento, nada aconteceu, 4 dias depois começou a dar esse problema.
Voeg je antwoord toe
Alloy L zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 33
Afgelopen 30 dagen: 107
Altijd: 2,961
