Ga door naar hoofdinhoud
The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
20 Vragen Bekijk alle
Disk drive making horrible grinding noise
My 360 s is making a horrible grinding noise and almost sounds like the disk is just being thrown around inside the tray. It'll start to read but then just go crazy. Anything I can do to fix?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Figured out the issue shortly after posting. So I'm leaving this up in case someone else has this problem. I was at a point I thought I'd need to replace the drive. But I took the top cover of the drive off and decided to try and remove the magnetic top spindle. Peeled back the labels and pressed out the circular lid out the top of the cover. Once I did that I noticed the 3 piece top spindle was separated causing the magnet to be off balance. It was very simple to realign the tabs with the magnet back in the center. After that I closed it all up and tried it out. Drive sounds like brand new.
I spent hours trying to find how to videos with this same problem without luck. So I'm hoping by leaving this up. Someone else will be helped by it.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Rob G zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 21
Altijd: 339
