Ga door naar hoofdinhoud
A more affordable, purely handheld version of the Nintendo Switch game console, with integrated Joy-Con controllers and a slightly smaller screen. Released September 20, 2019.
184 Vragen Bekijk alle
Dead switch lite diagnosis
I’m fairly new to fixing electronics (it’s a skill I taught myself during covid). I have this switch lite that doesn’t turn on and doesn’t charge. How can one go about diagnosing the exact issue with the switch? I want to increase my skills in fixing electronics, so any advice?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hi @eduardobau50221
Do you have a DMM (digital multimeter) and know how to use it?
If so then the first thing to do when you have a device that shows no signs of any power is to check if power is getting from the external power source to the motherboard. No power to the board means it won't work or can charge the internal battery
In this case it is via a USB-C port.
Use a strong light and a magnifying glass to check if the USB-C port is OK i.e. appropriate power pins not damaged or missing on the input side of the port and that the pins on the port output side are securely soldered to the motherboard.
Here's a link showing the pinout for a USB-C port.
Here's the ifixit Nintendo Switch Lite repair guide that may help to gain access to the internal components.
If the port is OK you will have to use the schematic for the board to start testing along the power supply path to see where it goes. Unfortunately, I can't find any online, (you may have better luck) so you will have to visually trace the path from the VBUS (and GND) pins in the port to see where they connect to and start testing the components along the path.
Without a schematic or a board layout diagram to know the type of component and its specifications it will be difficult to identify any board component that is connected to the input power rails to know what type of component it is and therefore what it should test if it is OK or not,
You may be able to identify any ICs which have their type number stamped on the case by searching for the datasheet for the IC but unless the smaller smd components have a board designation next to them on the board, e.g. F, FB, D, C, R, L etc (and mostly nowadays they don't) without the schematic (and a boardview file) it will be difficult to know
If you have another working Switch Lite device it would make it a bit easier to identify as you could measure the component with the Voltmeter or Ohmmeter function of the DMM to compare it to the same component in the faulty device to check if it is OK or not and to hopefully identify it, if it isn't. Welcome to the world of fault finding in electronic devices, without having a schematic ;-)
Was dit antwoord nuttig?
Score 1
Hi @jayeff I'm on the same boat (dead Switch Lite, no charge, no display) and I'd like to add more to this conversation, maybe even turn it into a go-to guide when it comes to dealing with a dead Switch Lite.
Before I go any further, I need to address some dependencies.
This is a good boardview for the Switch Lite: https://usoldering.com/switch-lite/
And this is a good opensource application to open the boardview with: https://github.com/OpenBoardView/OpenBoa... (just go to the releases on the right, pick a version for your OS, install it and you're good to go).
Additionally, more context about the Switch Lite is needed. Was it water damaged? USBC port was replaced? Any burnt component?
But because OP never mentioned that, I'll go with my case.
I got a Switch Lite board that's been tempered with. Meaning a modchip had been installed on it,owner says he had another technician remove it but after that, the handheld was rendered non-functional, so it's dead, doesn't draw any Amps when being charged.
Update (07/19/24)
So in my case, I've tried to bring this board to life by doing the following:
  • Making sure the fuse is beeping in continuity mode (it is);
  • Probing the fuse in diode mode (needs to be the same voltage drop value in each end of the component);
Next, I need to make sure that:
  • VBUS is NOT shorted (it isn't);
  • 5V (charging with USB2 charger) gets to BQ (it does**)
  • The coil next to BQ outputs 4.2V (it does**)
  • PMIC gets 4.2V and generates more voltages for 2nd boot (it gets 4.2V** but doesn't generate any voltages)
  • = WITHOUT battery plugged in
When the OFFICIAL battery is plugged in, M92 WON'T OPEN the 2nd MOSFET and BQ won't get 5V. Anything past the 2nd mosfet is dead and I haven't found out why.
Any help would be appreciated. Care to share your thoughts?
Voeg je antwoord toe
Eduardo Bautista zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 43
Altijd: 165
