Ga door naar hoofdinhoud
The third generation of the Toyota Highlander, a mid-size SUV.
My truck don’t what open
To close the truck by pushing the bottom, not what to close. I need to close with my hands.
Is dit een goede vraag?
1 Opmerking
@gitsel Could you please give a little more context and information about the situation?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Going on the assumption that the problem is the trunk won't close by pushing the button. VehicleHistory.com has a page devoted to the subject on your SUV here.
Toyota Highlander: Power Rear Door Not Working? - VehicleHistory
Here are a couple of highlights from that page.
Those are a few things to check. Try out these fixes and let us know what happens.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
I've tried everything under the sun, nothing seems to work
door
MOST likely issue is the glove box switch. It is on the upper left side. Open the box and look for it. It is not hard to accidently activate it OFF.
Voeg je antwoord toe
Gitsel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 43
Afgelopen 30 dagen: 268
Altijd: 2,267
