Ga door naar hoofdinhoud
Model A1502 / 2,6 GHz (Turbo Boost tot 3,1 GHz) of 2,8 GHz (Turbo Boost tot 3,3 GHz) dual-core Intel Core i7-processor met 4 MB gedeelde L3-cache.
Seam separated at one screw
I replaced the battery a few months ago. Little use since. Just noted space in back seam near one screw. Computer not hot. Should I worry?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
For piece of mind I would install this Gem of an App! CoconutBattery
It will allow you to see the batteries temp, If you want more on temps TG Pro will let you see everything!
Both of these are my goto tools.
OK, lets look at that screw! It's likely you cross threaded it as these screws are at an angle! I would take it out fully and rethread it in this time take note of the surface angle.
A simple trick here is take a business card draw a line spitting the long side into two equal parts now take the card place the line above the screw hole, place it so at the screw hole the cards edge is 90º to the hole shaft now follow this trajectory of the line with the screw. That should get you flush!
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
Yes. It was that screw but not misthreaded. There was a rubber fastener (instead of a screw) inside in that location that wasn't properly seated. Fixed that and put all the screws back. Case edges are all flush now, thanks.
door
@haroldappel - Happy to hear your bottom cover issue is resolved. Not forget to accept the answer - Thanks!
door
I did accept the answer, Dan.
door
Voeg je antwoord toe
haroldappel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 11
Altijd: 266
