Doesn't work or dosen't charge
Dosen't work or dosen't charge
Is dit een goede vraag?
Hi @izakb3360,
What is the model number of the charger?
Assuming that you have checked that there's no DC voltage on the output plug, you will have to open the charger and then first check if the wires in the charger's output cable have continuity from the circuit board in the charger to the output side of the connector plug at the end of the cable.
If the cable is OK you will have to start checking the components on the circuit board.
Safety notice: I suggest that you initially do this with the charger disconnected from any power outlet as there will be exposed lethal AC voltage on the board in the charger if the charger is plugged into a power outlet.
If you can't see anything obviously wrong post some close up images of the circuit board back here. Here's how to do this on ifixit
Was dit antwoord nuttig?
unless you want to get into soldering and all of that I advise you to buy a new one
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 36
