My laptop lights up when charging, but no other signs of life. Fixes?
Tried every known method, please provide me with a Guide.
Is dit een goede vraag?
Has it been dropped or bumped hard?
The hard drive might have come partially unplugged. Can you hear or feel it spinning? Is it a hard drive? Do you have a cover on the back to remove to inspect the hard drive
Will the DVD ROM tray eject?
We really need to know everything you can tell us about your machine. Manufacturer, model, Anything that might have happened to cause the problem or any damage, Did you buy it new, used, from a pawn shop, did you build it?
Was dit antwoord nuttig?
Battery may or may not be good, but a LT should run regardless on the adapter. You could remove battery and try it only on adapter, but the battery should not be the problem right now.
If only the power light ever comes on, then the problem is likely in the power button board or cables. I find cables loose in HPs frequently. Try unplugging and replugging cables first.
You can find a service manual here. Click "Download" at the top left.
Search "power button" in the document. (ctrl + F)
The cable is ripped.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 71
If you don't tell us what you have tried how can we help you?
door mike
I've tried all sorts of things.
15 second power button trick, QuickLaunch trick, safety pin, all of it.
door ved
