Ga door naar hoofdinhoud
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 Vragen Bekijk alle
using USB wi-fi adapter to connect wireless network
MY question is:
if I remove the wi-fi network card inside of my iMac, can I use any USB dongle to connect the wi-fi of my home network?
I want to remove wireless card cause I want to use miniPCIexpress slot for other purposes
thanks
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
you need one compatible with OSX.
I have this : http://www.amazon.com/gp/product/B002RCK...
for a similar problem, but not the same.
I do, or did have to use this on a older OSX based computer running 10.5..... i did have to use the little OSX airlink tool/program rather then built in airport to control it.
Not sure if this works with snow leopard or lion.
something to look into or maybe point you in the right direction, or look for more reviews etc..... i don't have latest info for wireless for mac since this worked fine for what i was doing at the time.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
joleisa zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 7
Altijd: 1,839
