2 Usb type-c not working
2 Type-C ports do not transfer data.
just charging.
cable works.
Is dit een goede vraag?
just charging.
cable works.
@freez0ne remember that the two port have different functions. The bottom USB Type-C port is charge and USB 2.0 data only.The side port (horizontal orientation) has video out and USB 3.2 Gen 1 transfer rate.. It is very unlikely that both your ports will have failed at the same time. This sounds more like a settings/software issue.
To transfer files from your phone to a computer:
1. Unlock the phone.
2. Connect the phone to PC by using the USB cable.
3. Scroll down the Navigation bar and tap the message for "USB Preferences" options. In "USB Preferences" options, select "File Transfer".
Let us know what your phone tells you.
What to do if the phone can not be detected by PC:
Was dit antwoord nuttig?
I cannot transfer data from the 2 USB ports on the phone. When I insert a USB memory stick, the phone does not detect it. I don't think there is any chance of both ports failing at the same time. This happened after the last update.
@freez0ne connect it directly to your computer via a cable. See if that works.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 64
