Can the the glass screen be replace
Need to replace the glass screen on my Apple - 21.5" iMac with Retina 4K Model:MHK23LL/A
Is dit een goede vraag?
Let’s make sure we are on the same pages here.
This system came in two versions of displays the standard and the 4K. The given system you have can only support the display it came with! So a standard will only support a standard display and likewise the 4K model will only support the 4K display as the logic boards graphics is designed specifically for the given display.
So… If you have the 2017 model with the standard display thinking you could upgrade it that’s not possible!
If you have a 2019 system here is the needed part Apple P/N 661-12564 and LM215UH1(SD)(B1) or YH215UHD(SD)(A1) which is marked on the display.
Here’s one source BeetsTech 21” iMac 4K display assembly
And the guide to put it in iMac Intel 21.5" Retina 4K-scherm 2019 Vervanging van het scherm
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 139
