Ga door naar hoofdinhoud
Een spelcomputer voor in de hand, gemaakt door Valve en uitgebracht op 25 februari 2022.
255 Vragen Bekijk alle
How to clean the inside components of my steam deck safely?
HI!
I was wondering how I can clean the inside of my steam deck, I never done this before and since I usually use my deck in a very dusty outdoor business, the inside of my steam deck is very dirty.
Thank you in advance for the help!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @milanorwolf
Here's the ifixit Steam Deck repair guide that will help.
It details how to open the console and remove all the parts.
The first thing that you should do when you start is to make sure that you have a clean work bench and are organized having the correct tools to do the work and enough containers etc to place in any components that you remove, especially any screws etc. so as not to lose them
After opening the console, first disconnect the battery as soon as it can be accessed so as to nullify any electrical problems from occurring when working inside the console. Mechanical damage .e. tools slipping etc is another matter so be careful and concentrate on what you're doing.
Wearing a wrist strap connected to an earth point will also minimize any potential for ESD damage to the sensitive electronic components on the board if you happen to accidentally touch them.
To clean off the dust etc, use a soft brush and gently brush it loose and then use a vacuum cleaner (lowest setting) to remove it from the boards etc.
When finished reconnect the battery just before closing the case for the last time.
If you strike problems, stop and think about it first instead of rushing headlong into trying to solve it as you may cause unnecessary damage. This forum is full of questions from users who tore cables, broke plug latches, stripped screws etc most probably due to impatience more than anything else.
Slow and steady and I'm sure that you'll be OK.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Milanor zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 26
Altijd: 64
