Ga door naar hoofdinhoud
Repair guides, disassembly, and troubleshooting information for the second generation Sony PlayStation 5 DualSense controller. Identified by model number CFI-ZCT1W and motherboard model BDM-020.
20 Vragen Bekijk alle
Headphone port removal and replacement
Hey does anyone have a video on how to remove and reinstall the headphone jack, I can see 4 solder points around it but my iron gets too close and just melt the plastics, same with the hot air gun. Any suggestions, thanks
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Flux it, use "Low Melt" solder, and lower the temp on the iron. After a little time the port/jack should just fall out. Wick away the old solder, solder in the new jack using 60/40 leaded solder.
Wait......by "melts the plastics" do you mean the controller shell?? O_o
Always remove the board from the shell before hand. :)
Was dit antwoord nuttig?
1 Opmerking:
Hey thanks for the response. Not not the shell, I take the board completely out, I meant the headphone port plastic itself. I will try what you said. Thanks.
door
Voeg je antwoord toe
Jordan Shaw zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 26
Altijd: 321
