Ga door naar hoofdinhoud
My headphones broke at worst place possible
Afbeelding
Afbeelding
My headphone broke at the worst place possible it is out of warranty and i have tried using glue but it only sticks for a while and then breaks it the same place. I have used fevi quick and fevicol
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Filteren op:
@alfiaali you are right. That is pretty much one of the worst places since no adhesive will work on anything that is supposed to move/swivel. You could try to use some two epoxy adhesive and not try to readhere the broken part but to disable it completely. Apply the epoxy to create a solid part.
Place the broken parts close to each other but leave a bit of an air gap. Wrap a piece of cardboard stock or similar around it but leave enough of an opening so you can pour teh epoxy in there. After the epoxy has drie you can remove the cardboard. Unless you sand is etc, it'll look pretty gnarly but should work. It will forever prevent you from removing that or to work on that side etc. but it should get the shell connected back on.
Was dit antwoord nuttig?
Voeg je antwoord toe
alfia Ali zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 23
Altijd: 642
