Ga door naar hoofdinhoud
Released in May of 2020, Model Numbers: SM-A217F/DS (Global), SM-A217F/DSN (Russia), Processor: Exynos 850, 3GB/4GB RAM, 6,5" inches display, 5000 mAh battery with 15W fast charging and USB type C.
109 Vragen Bekijk alle
حل مشكلة رمز pin للهاتف اوالرمز السري لا يعمل لفتح الهاتف لكنه صحيح اح
رمز Pin لا يعمل عندما اقون بوضع الكود السري لفتح الهاتف لا يفتح
Translation
Solution to the problem of the phone’s pin code or secret code not working to unlock the phone, but it is correct
The Pin code does not work. When I enter the secret code to unlock the phone, it does not open
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
@nimirirdeis if your phone does not recognize your PIN and you are absolutely sure that it is the right one,try a reboot. IF that does not work you want to try to get into your phone via Safe mode, You could also try an alternative method like your password.
To get your Galaxy phone into safe mode, follow the instructions given by Samsung:
1. Turn the device off by holding the Power button until the option to Power Off appears on the screen. Tap Power off.
2. Press and hold the Power and the Volume Down buttons at the same time, to turn the device on. When you see the Samsung logo appear on the screen, you can let go of the Power button while the device boots up. Make sure to keep holding the Volume Down button.
3. If done correctly, 'Safe Mode' will display on the bottom left corner of the screen. If 'Safe Mode' does not appear, repeat the steps above.
To exit Safe Mode, simply restart your phone and it will reboot normally. You can also enter Safe Mode by pressing the Power key, touching and holding the Power off icon, and then touching the Safe Mode icon.
Here you can try and see if you can work with your PIN or password issue. Anything after that would involve a hard reset which will delete your files etc. but check the video on here for more info.
Translation
@nimirirdeis إذا لم يتعرف هاتفك على رقم التعريف الشخصي (PIN) الخاص بك وكنت متأكدًا تمامًا من أنه الرقم الصحيح، فحاول إعادة التشغيل. إذا لم ينجح ذلك، فأنت تريد محاولة الدخول إلى هاتفك عبر الوضع الآمن، ويمكنك أيضًا تجربة طريقة بديلة مثل كلمة المرور الخاصة بك.
لإدخال هاتف Galaxy الخاص بك في الوضع الآمن، اتبع الإرشادات المقدمة من سامسونج:
1. قم بإيقاف تشغيل الجهاز بالضغط على زر التشغيل حتى يظهر خيار إيقاف التشغيل على الشاشة. انقر على إيقاف التشغيل.
2. اضغط مع الاستمرار على زري التشغيل وخفض مستوى الصوت في نفس الوقت لتشغيل الجهاز. عندما ترى شعار سامسونج يظهر على الشاشة، يمكنك ترك زر الطاقة أثناء تشغيل الجهاز. تأكد من الاستمرار في الضغط على زر خفض مستوى الصوت.
3. إذا تم ذلك بشكل صحيح، فسيتم عرض "الوضع الآمن" في الزاوية اليسرى السفلية من الشاشة. إذا لم يظهر "الوضع الآمن"، كرر الخطوات المذكورة أعلاه.
للخروج من الوضع الآمن، ما عليك سوى إعادة تشغيل هاتفك وسيتم إعادة التشغيل بشكل طبيعي. يمكنك أيضًا الدخول إلى الوضع الآمن عن طريق الضغط على مفتاح التشغيل، ولمس رمز إيقاف التشغيل مع الاستمرار، ثم لمس رمز الوضع الآمن.
هنا يمكنك محاولة معرفة ما إذا كان بإمكانك التعامل مع مشكلة رقم التعريف الشخصي أو كلمة المرور الخاصة بك. أي شيء بعد ذلك سيتضمن إعادة تعيين ثابتة مما سيؤدي إلى حذف ملفاتك وما إلى ذلك. ولكن تحقق من الفيديو هنا لمزيد من المعلومات.
Was dit antwoord nuttig?
Voeg je antwoord toe
Nimirir Deis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 57
Altijd: 131
