Ga door naar hoofdinhoud
Repair guides and support for gas, electric, and human powered machines used to cut grass, whether self-propelled or “walk-behind.”
installing a new blade
How to install a new blade on a Murray Lawn Mower model 20507x99c
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
the blade is attached to the engine via an adapter and a bolt that holds in onto the crank. Use either your own strength, or have someone hold the blade while you loosen the bolt on the bottom. You can also use a block of wood between the blade and the deck to prevent the blade from turning.Be careful that nobody gets hurt, use gloves or a rag to hold it. The tool to use would be either a box wrench or a socket. Sometimes those bolts are pretty tight and may require some extra torque to loosen. Hope this helps.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Miike zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 487
