Ga door naar hoofdinhoud
How to fix my phone screen lcd
my phone is glitching and have some lines of lcd
Is dit een goede vraag?
Score 7
6 opmerkingen
Folder change
door
My phone screen is broken
door
Display mein Pani gaya hai
door
When i touch my screen with one fingers it work but when i use two when im playing games it only works between my two finger(one of my finger)
door
LCD saya selalu rusak
door
1 commentaar meer tonen
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
@itsdanicacay that sounds like a broken display. you will have to replace the display. Since iFixit does not yet have a guide for this, use something like this video to replace the screen.
Replacement screen are readily available at many online places. Pick a seller that appeals to you.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Was dit antwoord nuttig?
Score 1
1 Opmerking:
My phone is broken the screen and lcd
1 Opmerking:
Maynard, is your phone a Realme C12?
If so, see the Most Helpful Answer above for the answer to your question(?).
Otherwise, you need to start your own question under the appropriate device category.
door
Cara mengetahui kerusakan hp realme c11
Google English translation from Indonesian:
How to find out if your Realme C11 is damaged
1 Opmerking:
Erikson, it would be much better for you to start a new question since your phone is different from the original poster's device. In addition, please include information about what makes you think your phone is damaged; what is it doing or not doing that doesn't seem right?
Erikson, akan lebih baik jika Anda memulai pertanyaan baru karena ponsel Anda berbeda dari perangkat pengirim pesan asli. Selain itu, harap sertakan informasi tentang apa yang membuat Anda berpikir ponsel Anda rusak; apa yang dilakukan atau tidak dilakukan ponsel tersebut yang tampaknya tidak benar?
door
Voeg je antwoord toe
its_ danicacay zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 86
Altijd: 1,636
