Ga door naar hoofdinhoud
Reparatiehandleidingen en ondersteuning voor videorecorders, waaronder Betamax en VHS-spelers (Video Home System).
Quasar VCR isn’t working
When the VHS tape is in the VCR there’s a spinning sound/catching noise, and it doesn’t play the tape. It doesn’t rewind or forward either but ejecting the tape is fine.
Update (12/29/23)
This is the info on the back of the VCR.
Thank you!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @eph23
Check if the drive belts are OK and not stretched or broken.
I can't find replacement belts for the VCR model online so if they are broken etc unless there's a part number on the belt itself (unlikely) you may have to purchase the service manual and check if there's a parts list in that, where the belt part number is shown so that you can search for it.
If the belts are OK then the service manual should help to find out what's wrong.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
@jayeff Thank you so much!! I will look into that and thanks for the link to the manual. I really appreciate it!
door
Voeg je antwoord toe
eph23 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 16
Altijd: 261
