iPod wire torn while screen replacement, how to fix?
I am replacing a iTouch and apparently I pulled the inner metal plate and it took along this little black piece with an attached blue and red wire. Well the blue wire tore and I'm wondering how I can fix this problem. Here is a pick of it so you know what I'm talking about.
http://i44.tinypic.com/2817xnl.jpg
Also, I was wondering what this specific piece is called and what is it for?
Which part is the wire connected to because I see two possible connection spots?
So heres an update, the wire I tore was the blue speaker cable. Does any one know how to fix it?
Update
There is some type of glue or clear rubbery substance covering the wire where it is soldered. How should I remove that in order to start unsoldering the old stuff. I'm trying not to damage anything else.
Is dit een goede vraag?
2 opmerkingen
Alright sounds like a plan, I will let you guys know how it goes. I need to figure out how to solder though, I have never done so in my life!
door Steven
the exact same thing just happened to me while changing the screen on my 4g...did you manage to fix yours? and will it still work without fixing the wire?
door Alec
