Ga door naar hoofdinhoud
A1418 | EMC 2889 | Late 2015 | 1,6 GHz dual-core Intel Core i5 of 2,8 GHz quad-core Intel Core i5. Uitgebracht op 13 oktober 2015.
audio jack not working
repairing the audio jack - what do i have to remove to access and repair the audio jack. It no longer provides an audio signal to headphones plugged into it.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
I would just get a USB-A DAC adapter like CableCreation USB Audio Adapter as replacing the iMac headphone port is a lot of work as you need to take the logic board out to gain access to the port which is glued to the case so you can get a heat gun to it to soften the glue. Follow this guide iMac Intel 21.5" EMC 2889 moederbord vervangen and here’s the needed part Headphone Socket and Cable
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thanks for providing bot a practical answer (which I will go for) as well as a link to the full solution which looks a bit difficult for me
door
Voeg je antwoord toe
Gordon Webb zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 43
Altijd: 402
