Ga door naar hoofdinhoud
Model A1224 / begin 2009 / 2,66 GHz Core 2 Duo-processor
How do I fix black screen?
Here are the symptoms:
-When you press the power button, the screen flashes white twice, then stays black. Otherwise, everything else starts up normally with the chime and hard drive sounds, etc.
-Shining a flashlight to the screen shows it still works (just no backlight?)
-I've reset the PRAM, no go
-I've replaced the inverter board but that didn't work
-It does work with an external monitor attached
I am currently running an extended Apple hardware test to see if it brings up anything specific.
Could something on the logic board be bad?
Bad CCFLs?
Is dit een goede vraag?
1 Opmerking
The hardware test did not find anything. Bummer.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
It's the screen connection to the board, screen or video card
Here is the screen guide, take it apart and check the screen connector, if nothing, try a a screen
iMac Intel 20" EMC 2266 Beeldscherm vervangen
If not, it's the video card or logicboard(I think this model has a MXM card)
I do not know much about the video card built onto the board or a seprate card, but I know this, if it's a ATI(AMD now) or NVIDIA, it's probably on a separate board, if it's intel, no, on the logicboard itself, you will need to take your iMac apart to know for sure about this
Here is the GPU swap guide
iMac Intel 20" EMC 2133 en 2210 videokaart vervangen
iMac Intel 20" EMC 2266 Beeldscherm Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
iMac Intel 20" EMC 2133 and 2210 Videokaart Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
1 - 2 hours
Was dit antwoord nuttig?
1 Opmerking:
thank you nick, i really appreciated you, its also solve my problem
door
Voeg je antwoord toe
mike zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 2,717
