Ga door naar hoofdinhoud
Een Android-smartphone gemaakt door vivo.
Why battery draining down fast
Battery draining fast
Is dit een goede vraag?
Score 11
9 opmerkingen
Battery drains fast I am vivo phone
door
@kishorekishore How old is your battery? Is this something new or has it been getting steadily worse? Have you considered @jayeff's advice to replace the battery?
door
Battery drain fast
door
Battery draining issue
door
Very bad battery
door
4 commentaren meer tonen
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hi @aijazahmed
Try replacing the battery and check if that resolves the problem.
Here's a video that shows what to do.
Search online for B-H0 battery to find battery suppliers that suit you best.
Was dit antwoord nuttig?
Score 6
First, check if the battery is bloated or not if it is bloated change it with a similar 4500mah battery.
If the battery is not bloated first change the app's background running setting to off from setting and stop other background processing you don't want.
Next, stop all unnecessary notifications and turn on the dark mode it boosts your phone battery life.
If it didn't work try replacing the battery and check if that resolves the problem.
Score 5
Voeg je antwoord toe
Aijaz Ahmed zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 80
Altijd: 2,765
