Ga door naar hoofdinhoud
Nintendo Game Boy Advance, uitgebracht in 2001. Voor reparatie zijn alleen gangbaar gereedschap nodig en geen hitte.
Very dark screen when playing games
I’ve just purchased a second hand game boy advance and it’s quite hard to see the game due to dark screen. I’ve tried the usual holding select and clicking left/right but no good. Also found the pot behind the serial number but no good unless I need a very small screwdriver but not sure. Any help greatly appreciated
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
The Game Boy Advance doesn't use a backlight, which can make it hard to see the screen in low-light conditions. If you are willing to take apart the GBA and use some tools, there many backlight modifications on the web that can be used to help install a backlight into your GBA. But you must keep note: by installing a backlight mod into the GBA, you must do it correctly, as you could cause damage to your GBA if done incorrectly. You will need some tools, and a soldering iron, for the task.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Lee Wheller zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 55
Altijd: 2,573
