Ga door naar hoofdinhoud
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
20 Vragen Bekijk alle
Kenmore model #110.22622100 Lint on clothes after the wash cycle.
Kenmore model #110.22622 100
Is dit een goede vraag?
1 Opmerking
I do not have the lint catchers at the bottom of the tub on my Kenmore model 110. 22622100. Where else would I find them if any?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi @sally74356
The filters in the bottom of the spin basket may need cleaning or replacing.
Here's a video that shows where they're located.
If new filters are required, search online for 285868, to find suppliers that suit you best. (comes as a kit of 4 filters plus instructions)
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
Thanks Jayeff for the answer. I was hopeful but upon watching the attached video it is nothing like my Kenmore top load washer model #110.22622 100. It is about 15 years old and I have never cleaned the lint trap or have know where it is. One thing that is somewhat similar is the agitator has a lid that you pry off with a flat head screw driver and then deep down in the agitator is a screw which I have tried everything but a socket wrench. I am going to look to see if I have on like in the video and try that. Wish me luck! Thanks again! Sally
door
@sally74356
Seems less of a full trap and more of a screen that allows the smaller lint pieces to pass through to be drained away e.g dissolved tissues like I'm always forgetting to remove ;-( rather than clinging to the wash etc and prevents any larger items from being lost.
I was only going by the parts diagrams for your model.
See Item # 12 Agitator/Basket/Tub parts diagram.
They call it a "plug" others call it a filter - go figure
When you click on the part linked below the diagram, there is a box that asks to "confirm the part fits" with your model and it does
door
@jayeff interesting….I believe you are correct sir! I can’t thank you enough for the time you have taken to help me with this issue. I am grateful and relieved. Thanks again! Enjoy your day!
door
@sally74356
After 15 years hopefully the nut isn't too difficult to remove.
Good luck
Cheers
door
Hi @chris31172
According to the parts list (Agitator/Basket/Tub diagram - see Item #12 in image below) there are "plugs" under the agitator that act as a screen more than a filter and they allow the smaller lint pieces to pass through to be drained away and prevent any larger items from being lost.
See the Chosen Solution above on how to check and replace them. The part number linked above is applicable to the plugs used in your model as well.
There are no other filters in your washer.
Are you using too much detergent perhaps? Using too much is another cause of lint on clothing. Follow the washing machine recommendations on how much to use (or even half that amount) in your washer and not the detergent manufacturer's amount. They only want to sell detergent
(click on image)
Voeg je antwoord toe
Sally zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 49
Altijd: 616
