Dim LED’s moves around after restart on my Vizio P55-C1
Got some dim led’s that can only be seen on white background & rarely gets worse. Seeking solution.
I am pretty sure it’s not the failing LED’s cause recently I changed thermal paste & reflow my main board & there was no dim led’s anymore. Also dim led’s move around the tv after every restart or shutdown. Sometimes it’s only in the middle right of the tv & little more darker & other times only in the centre & very faint or on all sides & is also very faint. Only can make out in white background mostly & when i think i can see while watching something, i just restart my tv & it fixes for few days. Is there any permanent fix to my problem & what’s causing this ?
Is dit een goede vraag?
Edit: it was infact failing LED’s & i ended up selling it but reflowing the board & applying the new thermal paste made it work a little longer & no glitches that i was getting as it was heating up
door Hny-B-King
