Ga door naar hoofdinhoud
Canon MiniDV camcorder with 18x optical zoom and 360x digital zoom
2 Vragen Bekijk alle
How can I fix my black screen on my Canon ZR60
My Canon ZR60 has a black screen and I heard that it might have something to do with the CCD but I have no idea how to fix it. The camera also records audio just fine its just there's no picture playing when I press record.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @cvez1079
Can you view your recordings when you connect the camcorder to a TV?
If you can see your recording on the TV then it may be just a problem with the LCD screen in the camera.
When trying to view a recording in the LCD screen (I realize that you can't see anything on the screen) try shining a flashlight at an angle close to the LCD screen and check if you can see any images on the screen.
If you can see images then it is a LCD screen backlight problem or a screen backlight power supply problem from the motherboard.
If you can't see images then it might be a LCD screen and backlight or motherboard problem.
Since you can see images OK on the TV then more likely it is a LCD screen problem.
If you can't see your recording on the TV then most likely it is a lens or motherboard problem.
Here's the service manual that will help.
It has the disassembly procedure (for the LCD unit see p.5-14), the parts list and schematic diagrams as well.
A quick search online for the LCD unit showed no results for suppliers. You may have better luck.
Hopefully this is of some help.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
cvez 1079 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 19
Altijd: 88
