Ga door naar hoofdinhoud
The Samsung Galaxy A31 is a mid-range Android device released by Samsung in April 2020. Identifiable by model numbers SM-A315(F, F/DS, G/DS, and G/DSL).
White Line in phone
My Phone has white line in the middle of the phone screen. how to remove this white line from phone?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Jiwan Kumar, extraneous lines on smartphone screens are usually an indication that the screen has failed and needs to be replaced. Of course, before you do that it will be worth your time to try and reset the phone, and if that doesn't help you should back it up then restore it to factory settings and see if that helps.
If you add a photo of the problem you're seeing on the screen that may help us with diagnosing the issue, but based on just what you've said it sounds like you should replace the screen.
Voeg afbeeldingen toe aan een bestaande vraag
Was dit antwoord nuttig?
Score 1
Middle me ha line white
Voeg je antwoord toe
JIWAN KUMAR zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 159
