Why isn't the battery working? I already replaced it with a new one.
Why doesn't the camera battery work, even though it has been replaced with a new one?
Is dit een goede vraag?
@agungpringgo the issue may not be your battery. The issue could be that the camera does not get any power. The first thing to check, would be the fuse that sits on the main circuit board, right past the battery connector. Check that one for continuity.
Use these guides Panasonic DMC-FZ70 to work on your camera. Once you get to the motherboard, post some good pictures of both sides of the board. That way we can see what you see and hopefully help you further. Voeg afbeeldingen toe aan een bestaande vraag
Was dit antwoord nuttig?
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 44
@agungpringgo Do you have a multimeter so we can check the voltage of the batteries?
door Andrew S
