no power in 2 Wii remotes
Two of my Wii remotes no longer turn on, one of them had a small amount of corrosion in the battery compartment, and the other one has a little bit more in the battery compartment, and some in the nunchuck port. I tried to cleanse the port and the compartment on both, but the problem persists.
Is dit een goede vraag?
Have you properly cleaned battery terminals? (Checkout guide Het schoonmaken van gecorrodeerde batterijpolen) Have you tried using new batteries or checking if the ones you have are charged? Are you using rechargeable or disposable batteries?
door dinoo_fixit
