Ga door naar hoofdinhoud
Ondersteuning voor de Texas Instruments TI-84 Plus rekenmachine.
Why is my screen frozen
When I turn on my calculator I none of the buttons I press work, the cursor is blinking on the screen but I can’t even turn the calculator off. I tried removing the batteries and charging it and that didn’t work.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Hi @leighacox
Try the following and check if it resolves the problem.
Remove the batteries and the back up battery from the calculator and then press and hold the ON button for a full 20 seconds and then release it.
Note: Remember the way that the back up battery was installed (+ve on top as seen on the battery itself) so that you reinsert it the correct way.
Reverse the procedure to reassemble the calculator and check if it turns on and works OK.
Here's the ifixit TI-84 Plus uit elkaar halen guide that may help. You don't have to go past Step.5
Was dit antwoord nuttig?
Voeg je antwoord toe
Leigha Cox zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 89
Altijd: 1,672
