Why is my phone having issues charging?
For the past few weeks, my phone, Samsung Galaxy S20 FE 5G, has been having issues with charging. I've bought numerous NEW cables and NEW adapters. The issue with the charging is when you plug the cable into the port, it will show its charging fine for a split second. And, when you tilt/move the phone around (regardless of direction), it stops charging like the cable is busted. But, the cables I've tried are all NEW, which is part of why I'm baffled. And, I've also tried carefully cleaning my port with a toothpick and compressed air. In addition, the port doesn't look like there debris in it. And, I'll add that the piece where the cord plugs into the port is wobbly, but doesn't easily fall out with movement.
Is dit een goede vraag?
