How do you fix the Blue Inductor Coil on iPhone 4?
ok so i have an iphone 4 and after it was droped the screen broke and my wifi was weaker so i pland to fix the sreen and just redo all the glass as red and the fram as black and well replacing all that i put a new wifi antenna in to see if that would fix the weak wifi well i did not, and now just this week i now have no phone service and still weak wifi, i looked up online and some one said that the blue coil by the wifi and battery plug could have broke, i looked and i think it may be i found the part i need to fix it online. is there any way you can put something up to show how to replace it, thank you
Is dit een goede vraag?
3 opmerkingen
Hey guys, this awnser is not correct... This blue filter is for cell phone receive not wifi, wifi chip and traces are on the top side of the motherboard.
Greetings
door NicolasN
Hello!
I have an iPhone 4 it fell down and
Display is broken.
And sim signal is not working it said
No service
Then some one told me to check
Blue coil top of ringer
It would be broken
I see it
Was broken and I don't know how to fix it please tell me how to fix it
Thank you very much.
door Burhan Amjad
When you have not blue coil for change .you can remove the blue coil from the board and connect the two points together with the solder .it work 100 % in iphone4 without problem
door sadegh harati
