Why is my mobile not charging properly?
My device doesnt start charging until its switched off and charge also doesnt last for very long as before.Sometimes charge becomes lesser and lesser even when in charge
Is dit een goede vraag?
@bidursubedi first you want to check if there is a software update for your phone available. IF there is, update it. If that does not yield any results, you may need to try a hard reset. Make sure that you have all your password, access codes and all your files backed up. A hard reset will delete all of those. Do NOT perform this if you do not have your passwords/access codes etc. Here is how to do a hard reset and if you can't do that, at least try a soft reset
Symptoms like this "charge becomes lesser and lesser" are usually caused by a bad battery. Use this guide Xiaomi Redmi Note 10S Battery Replacement to repalce it. After that re-evaluate
Was dit antwoord nuttig?
check charge cable and adapter then usb socket then cgarger inner of phone main board battery and battery charger chipset. one of them broken/errored.
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 73
Altijd: 232
