Ga door naar hoofdinhoud
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
intermittent f6 code flashing on display.
Hello,
I get a f06 code on the washer when I run a complete wash cycle. I can usually run a rinse and drain cycle. I read the f06 post and tried unplugging and replugging various connectors on the CCU and MCU. I suspect a failing part, possibly a speed or rotation sensor. Where are these sensors?
Is dit een goede vraag?
9 opmerkingen:
Hi @mron,
What is the model number of the washer?
door
It's an elite quiet pack 4
door
@mron
The model number would help to ensure that if parts are required that the correct part can be found.
door
110 45972400
door
110 45972400
door
4 commentaren meer tonen
Voeg een opmerking toe
1 Antwoord
Dit antwoord was oorspronkelijk aan een andere vraag gericht.
Hi @mron
There is no balance sensor in the washer. At least there's none shown in the parts list for the washer.
Intermittent problems can be hard to find so perhaps try checking the connections between the MCU and the drive motor to see if they're all OK i.e. not loose, corroded etc.
Here's the tech sheet for the washer that may also help. On p.8 it describes how to check the windings for the motor, just in case one winding is not within spec or is on the limit of what may be acceptable to the MCU.
Was dit antwoord nuttig?
1 Opmerking:
The tech sheet is very helpful! thanks
door
Voeg je antwoord toe
Ron Moreland zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 164
